Ryu James
Ryu James's Avatar
07.19.2009, 07:12 PM
Originally Posted by florianz View Post
carbon fiber brake discs, cool. do you have to balance the break-power or does that work automatically? I remember that from eg. old landrover, when the mechanical breaks are not well adjusted, the car turns right or left when breaking.
because the center diff is locked on this truck that wont happen. technically i could only run one set of breaks and it "should" work. if i do notice anything like that though i can adjust the grab of brakes to be equal all around by adjusting the width of the pads so that all 4 grab at roughly the same time. i really wish i had a viscous center diff and could then dial in front and rear bias. i am doing the the 4-wheel brakes now even though they are not needed cuz i hope to build a viscous center diff at some point in the future. i guess it will depend mostly on how i like the locked center diff.
Jammin SCRT10 Neu 1512 1y
