07.19.2009, 08:28 PM
Originally Posted by Freezebyte View Post
I'd rather not deal with trying to modify/run a 5S pack on a Flux, its not specced for that type of wiring/Lipo.
It most certainly is. Its speced for 4 THROUGH 6s, that means 4,5 or 6. You've just seen everybody pair their lipos and choose 4 or 6s.
You're into it this far, go up to 6s and reduce your gearing for the same top speed as your 4s setup, everything will run cooler and happier.
I know from running nitros how quick the little engines overheated running in grass, so I mostly avoid grass runs with my electrics. Good Luck!
