07.19.2009, 11:32 PM
Originally Posted by fastbaja5b View Post
I don't doubt that, and if I felt the MMM was up to running a 5s/6s set up reliably I probably would.
But I don't think it is, the failure rate on 5/6s as against the failure rate on 4s is simply far too high!
Hmm, only one out of 5 I have had died on 4s. The other have ran fine on 5 and 6s. And the dead one was a bec failure, I even did the BG mod to it and it works fine with an external bec.
As far as failures go, are you considering just fet failures, or the bec failures as well? I do not consider the bec failures, as that was a component problem, not a design issue. And it has been rectified.
