07.20.2009, 02:33 AM
Originally Posted by fastbaja5b View Post
Could I replace my MMM speedy in the Flux with a Hobbywing 150? I am finding at least locally a high failure rate on the Savage Flux ESC's and mine is starting to show signs such as the fan being on 95% of the run and that's on bone stock gearing with 4s 30C 5000mah packs.
I'm just not that confidient in it's reliability right now and am still waiting a reply from CC on another MMM with an issue I emailed them about some 2-3 wks ago.
Ok, here is the reason for your MMM fan being on all of the time...
First off you have stated in other threads to be using Harris 5000 30c 4s lipos, and that they are dropping voltage quite a bit. So they are overrated, and also not able to keep up with your flux. 2 fixes, better batteries or lower gearing...
Lets examine what happens when the voltage drops. The motor is still asking for the same power, the esc is still feeding the motor, but the batteries are dropping voltage, so the amp requirements are climbing fast. Since watts = volts x amps if you loose voltage you need more current to maintain the same output at the motor. So the increased current draw thru the esc will cause higher temps in the esc. To prove this get some crap nimh packs and see how they heat up your motor and esc, they just cannot keep up with the load, drop voltage, amps spike, voltage drops lower and everything gets hot fast...
Get better lipos and you will find esc temps will go down and performance will improve. If your lipos cannot maintain over 3.5v per cell under full load you need better lipos, that is a rule. If you hit the lvc during a run you need less load or better lipos.
4s in a heavy MT is not optimal, go up with the voltage and you can use lesser rated cells, if you really want to. The MMM is prefectly capable of handling 6s, just use decent lipos.
And your eagletree most likely samples the voltage much faster than the MMM does, thus you are dropping voltage and recovering faster than the lvc can kick in. I have tested the effectiveness of the MMM's lvc, and it does work.
