Overdriven
Destroyer of Tires
Overdriven's Avatar
07.20.2009, 09:22 AM
Very nice, I'm jealous. And I wanna see a closeup of the brakes without the disc. I'm curious where the mounting holes lined up.
With your brake bias, your right you don't have to worry front to rear right now. But you do have to worry about left to right, as there is a diff between them. If it is off it'll probably be most noticable when you first apply the breaks, or when applying light to moderate pressure. The solid center diff will help even things out alot, as each wheel is not as independant. With your skills I'm sure it'll be setup pretty close on the bench either way. Keep it up
