fastbaja5b
fastbaja5b's Avatar
07.20.2009, 08:46 PM
Did you by chance purchase those on Ebay from "hopmeup"? If so, I'm guessing you were one of many who ended up buying old cells. There was a thread on this a year or so back. I bought six packs from them, and ended up with 4 after I rebuilt them and pulled out the bad cells.
Back to the topic at hand - Freeze ya need a break from this. Still not an excuse to use language like that.
I for one have a hard time thinking that both packs puffing at the same time is due to bad cells. If it is, you definitley got some bad mojo going.
Yeah I did actually, likely a contributing factor!
Can you run a 3s and a 2s on the Flux? The manual says both pack needs to be equal. I didn't think I could even run a 5000mah and a 5100mah pack or a 28C and a 30C pack, what I interpreted was both packs must be identical.
Say Less, Do More.
