Originally Posted by JThiessen
Did you by chance purchase those on Ebay from "hopmeup"? If so, I'm guessing you were one of many who ended up buying old cells. There was a thread on this a year or so back. I bought six packs from them, and ended up with 4 after I rebuilt them and pulled out the bad cells.
Back to the topic at hand - Freeze ya need a break from this. Still not an excuse to use language like that.
I for one have a hard time thinking that both packs puffing at the same time is due to bad cells. If it is, you definitley got some bad mojo going.
Yeah I did actually, likely a contributing factor!
Can you run a 3s and a 2s on the Flux? The manual says both pack needs to be equal. I didn't think I could even run a 5000mah and a 5100mah pack or a 28C and a 30C pack, what I interpreted was both packs must be identical.
