Originally Posted by hemiblas
Woops, you know what, it an 8L purple feigao. Sorry about that. I can only read the 77A max sticker and the .0076 ohm on it which I think corresponds to an 8L motor. So a 7L would be higher than what I gave you. Ya I just hooked up my wattmeter and let it run full blast for a couple of seconds. I tried a couple times to be sure, but you dont want to run these things unloaded for too long.
33A peak on 3S sounds fine. In fact that might be a bit low. I'm assuming its a light buggy to get that number. But ya looks like it is ok.
Hey thanks alot. 33A peak on 3S was tested on a low traction surface. Asphalt or grass will definitely result in a higher peak current.
