ta_man
07.23.2009, 12:34 PM
AND one you turn on the pack switch, you need to turn the ESC switch on then back off (info that is NOT included in the instructions).
Ta Man: Have you ever used that Novak BEC before? In the link it says it allows up to 7S usage, but I'm fairly certain that does not mean that if you added this, you cant then run 5,6,7S on the HV system, correct?
I have one of those BECs on my Havoc 3S (the internal BEC won't run a high torque servo on 3S).
Right: You can't run more than 4S on the HV system just by adding a BEC that can take more than 4S.
Well, you could try, but Novaks aren't like Castles (the MM for instance that lots of people use on 4S and some even on 5S).
