zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.23.2009, 01:42 PM
Linc, are you sure that FP and Hyp. are not that same cells? They both seem to advertise the same specs, 5C charge, 4x cycle life...
Even like I said in my last post, a few of the packs in the lineup seem to match up perfectly as far as weights go, and the difference in mah, could just be FP rating their packs conservatively?
Or maybe all the brands really are sourcing from different manufacturers, and they all just payed royalties to a patent owner for the same cell chemistry/manufacturing process?
BTW, I think Hyperion might be coming out with a 40 - 45C pack soon, as they still have their "VZ" line to fill in with G3 packs.
Also, TP 40C packs seem to be the same cells as G3's, only slightly more powerful... same discharge curve and everything, just slightly higher voltage under load. (proportional to 40C vs. 35C)
Only time will tell I guess.
