07.23.2009, 05:03 PM
"a bad switch might make someone send in a perfectly good MMM for warrantly work that would otherwise not have happened."
Ulterior motive? lol
Seems the micro switches die alot because they don't carry enough current to keep the contacts 'clean' -- I know this applies more to AC, but as an example I put LEDs in my bike's taillight years ago. They were the socket-type drop ins, and I had real problems with them flickering or not working at all, until I hardwired them. Figured out that there just was not enough flow there and the slightest corrosion was causing a broken circuit.
Now even under ideal conditions the switches seem iffy, add some salt, sand etc to the equation and.......
