07.23.2009, 07:31 PM
That looks like a FD L can. That motor/esc will not handle those tires. Have you upgraded the transmission (locked in 2nd, steel idler) or is it stock? If it is stock, those aforementioned mods are mandatory. IMO get the gmaxx single speed kit, a strobe sprong (if you can find it) and a RCM idler. If you want to hang on to those wheels and tires, ditch the mtroniks esc and the FD motor in lieu of a MMM 2200 combo. That'll move that sonofabitch nicely. Also consider upgrading to 5s if you get the 2200 combo. If cost is an issue, you can buy one of the refurb combos (refurb esc and new motor) for $225 from CC's site. There's a thread on it in the CC forum. Check that out. Also, go 2.4ghz if you are not already. Hope this info helps.
Ian
