03.10.2005, 11:52 PM
If you follow the Pro-line instructions, the "saver" part is on the side opposite the steering servo. The "extra" turnbuckle is their method of reaching across the truck to this bellcrank (passes through center of the truck). I usually mount it on the servo side and use a short linkage like the stock setup.
