watercooling
transtalon
watercooling - 07.25.2009, 10:21 AM
The links for the water reservoir looks tricked out. I think this is all you need and the pump that they are selling. The TCS pump is small and looks real good. But it works good as long as you don't roll over as it needs gravity to feed the pump. Also you need a high volume tank for it to work as the more water it has the more pressure gets deliver to the pump. I tried it but it's very unpredictable on pumping water. You'll just find out it's not working when you check the temps on the water. When it works the temps is about the ambient temp of the outside but when not it gets pretty hot. Watercooling really works on cooling the motor, it's pretty amazing to see that my motor went from 170 degrees to 98 degrees on a 90 degree weather.
