07.25.2009, 12:56 PM
BTW: An ESC will register as a dead short at first if the caps aren't charged up. A meter outputs a small voltage and if the caps are discharged, the meter charging them will look like 0 ohms. Give the meter about 10-30 seconds and you should see the resistance start to climb as the caps charge...
