07.26.2009, 12:24 PM
Did you open the case and/or do any soldering to the board? If the answer to both these questions is "no", then they should cover it under warranty. The only way to know for sure would be to contact them and explain what happened.
That said, if your setup was done in such a way so there was strain on the receiver wire, that would be more of a user problem.
