danhfvcsd
07.27.2009, 12:00 AM
Originally Posted by Duster_360 View Post
The lids don't open far enough to get these thick lipos inserted, 2S lipos have no probs.
Can you cut off the 2 'tabs' on the top lid of the battery boxes to get them in there maybe? You could just use velcro straps to keep them securely closed =)
I have some 9000mah SPC 2S packs that are a decently tight fit on the sides, and they JUST scrape past the 2 'tabs' on the lid of the battery box with a tiny bit of muscle =)
The only problems i have found with my flux is the bloody rod ends on the turnbuckles - mine had flexed and stretched on only the first day of use on only small bad landings, which left me with quite a short day... have since replaced em with lunsford alternatives which are holding up well.
That, and it's too short... i can barely keep the front wheels on the ground on only 4S with a MMM/Neu 1515 1.5d/F... Will be going for the extended flm chassis on this eventually - it's uncontrollable... I get rolling backflips with big joes on... It's fun for a short while, but gets old pretty quick. (yes - i have toned down the esc settings)
other than that, i've had no probs =)
