zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.27.2009, 11:33 AM
I can hear the difference between 2 amps running the same speakers with the same source material and head unit... I do have an above average IQ, but I doubt that is helping me out much in the listening department...
Nothing against lab equipment, but the human ear is much more sensitive than the best equipment you can find. Plus it can interpret many more variables at the same time than lab equipment. Tube amps sound warmer, different crossover setting impart a different sound and feel. Various digital to analog converters will produce different sounds. I did high end car audio when I was younger and there is a big difference.
And yes, shit can be built cheaper in china than anywhere else... Why do you think most things have made in china stamped on them...
Oh I didn't even notice your post Linc. You are right, the human brain actually is what is doing the listening... and yes, you can hear differences that a techy in a lab says you are full of shit. There are some things that test equipment is pointless to be used on, and hi-fi audio is naturally one of those things. Not trying to be a braggart, but I can tell the difference between O.F. copper interconnects and silver interconnects, as well as the difference between two different rectifier tubes on the phono-stage preamp. It has a lot to do with the system being very natural, open, and almost free of influence/dampening. This is on a new gen. turn table might I add, which up until 3 years ago, I thought was an inferior medium to store music on.... quite the contrary.
Metallover, you need to have a graph that has notes about each brand's pack, such as FP and Hyperion have much higher cycle life than other brands, and FP, Neu, Hyp can be charged at 5C rates, etc...
