07.27.2009, 12:37 PM
Ryu: Just a suggestion, if you end up using watercooling, you probably wont be able to use that box. It looks like a tight squeeze as it is, but you will have to add tubing to connect the cooling plates. They add a bit of size to the esc.
Otherwise it looks amazing! I can wait to see this in action.
