Originally Posted by zeropointbug
I agree, you should go with 4-5k-mah on 4s... but seeing as you have a TP 40C 5000mah, and your mains are only 10 mins long, I would hardly worry about anything. If your mains were longer yes, for instance, I have 30 min mains at my local track, I use 6s 4200mah packs, and swap out at 15 mins, each pack has 20+ mins of runtime though, provides peace of mind.
You COULD use 3200mah 4s pack, but it would have to be a high end pack, such as a TP, Hyp G3, Neu 35C+, etc.
ah. I have an SMC 40c 4S 5000mAh, but interestingly enough, my motor gets a bit warm with it.
am I being too heavy on the trigger? perhaps.
the pack I saw was a PolyQuest 4S, 25c I tink.
