07.30.2009, 04:10 AM
what timing did you use? timing has a big effect on the performance. higher timing must not cause a much hotter motor, but by far better performance. just try out. every motor has it's ideal timing.
I have a losi 1700kv 4pole motor, and there's a big difference between 1 and 7 degrees timing.
just take the tekin, try out a higher timing step by step and I bet that you're surprised... I just can't believe that tekin/neu makes such weak motors.
