Thread: Li Po
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.12.2006, 10:38 PM
I use a kokam 3200 mah 20c (64 amp) pack. The main thing is that you make sure the max continuous amp rate is above 45 amps, assuming your running 3s lipo and 9 turn 380 motor. You need at least a 60 amp 2s pack for a 6 turn 380. How much runtime are you looking for?
Area 52 Ranch Raceway
T.R.C.R.
