01.12.2006, 10:48 PM
You need a 50 tooth spur and a 21 tooth pinion or something similar to that ratio. Final drive ratio should be 6.5 and on 10 cells, you will get you 45-50 mph. It will be interesting to see how this system accelerates. I don't know how much throttle control you will have with a 22000 rpm motor.
