justpassedu
07.30.2009, 12:43 PM
i think it may be 14t stock but im not sure aswell, but why would you doubt id be pulling 40+ with this castle motor , i have done over 60+ in other vehicles with this same motor , it is a 5700kv , its really not a bad motor , i mean i have had better but this motor aint so bad aslong as you keep temps under control. honestly id really like to be doing 50+ in this hyper mini with this motor , what gearing do you think i should go with to achieve that or do u think i should jsut pick up a 3slipo? also it is the newer version of the 5700kv motor , few small changes i used to have the older one and it overheated all the time. I also have a vxl motor laying around but this 5700kv will produce a higher top speed and thats what im looken for speeed ...
