Originally Posted by david lamontagn
The only motor and batterie i have is a castle/Neu 1515 2200Kv and an hyperion 3300mAh, 5s lipo, i know it's a little crazy for a crt.5, but is this motor can fit in this little truck??
The only missing item is the RCM motor mount, but i want to know if i can fit this motor in my truck?
I know i'll have to place shim under the center diff mount, but for the rest of the fitting process, is all will fit fine?
Thank you!
David
Look, this is the CC Neu i have
And i don't have the RCM chassis but for the pack, if i put it on it's side, i'll mount it easily.
You're sure that i can mount a CC Neu finned can without shim under the center mount?
