07.30.2009, 02:07 PM
~9.7v @ 80amps = 60c.. ermmm.
It is actually putting out 60c bursts- the voltage stays around 3.3v per cell, the current being drawn is up around 75-80amps, so 80amps / 1.35amps (1350mah pack remember) = 59.xxx. If you go by the heavier bursts, then its putting out around 40-50c bursts.
The weird thing is that some of the smaller bursts around 65amps are what cause the voltage to drop down to around 3v per cell. That I dont quite understand myself, could do with some more expert input & interpretation of the graphes.
It is still very impressive for such a small pack though, would love to see how a larger version of the same cell will perform.
