07.30.2009, 05:21 PM
I ordered one of those strap mounts from Jim Williams at southriverrcboats.com
I think if we could get down to a 10T Mod 1.5 pinion that would be ideal sdp-si.com has a 12T
qtcgears.com has a 42T spur but it has a hub so you would have to grind it off or something.
You might be able to shim the locker mounts and top plate up to get the 42T spur to fit but then you migh run into binding on the dog bones. sdp-si.com does sell u-joints...
