Jason
07.31.2009, 03:49 PM
the stock diff ratio is 2.8 how about if I put my kyosho diff the new ratio is going to be 4.3 .. ?
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 13
Total Voltage: 14.8
Motor KV: 2700
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0082
Spur/Pinion Ratio: 3.85 : 1
Total Ratio: 16.53846 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Total Motor Speed: 39960 RPM
Vehicle Speed: 30.91 mph (49.65 km/h)
Effective KV Value: 2700
KT constant: 0.5 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
