phatmonk
RC carbon junkie
phatmonk's Avatar
08.01.2009, 08:53 AM
[QUOTE=Bondonutz;308905]The diameter of the wanna-be NEU in my truck is 37mm diameter X 48mm Long. I had to grind the little hump on the chassis that is over the center shaft in order for it to get a perfect gear mess with 50/28. There is also 1mm gap between rear shock tower and the rear of the can.
Is your setup using the stock motormount?And if so what other mods were required other than the above mentioned.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
