wallot
wallot's Avatar
08.01.2009, 02:59 PM
It is beast off the line but there is a hole when going from low to mid RPMs then its beast again. It should be possible to eliminate the hole for example with Futaba 4PK and its throttle profiles but just RX8 profiles along with EXP on my DX3R did not help. Also couple fellow racers feell it the same and they played with timing.
However I am staying with neu. Runs cooler, linear power without any tunning and is over 50grams lighter.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
