Scott711
Scott711's Avatar
01.13.2006, 12:50 PM
Check the solder connections on each end of your batteries. I had a similar problem and found that one of the tabs had come loose and was causing Intermittent issues like yours. It can be tricky trying to re-solder a set of batts especially if they are factory assembled. Maybe check to make sure the red jumper on the 9920 has not come loose also. Good luck.
