Thread: Good shocks?
Finnster
KillaHurtz
Finnster's Avatar
08.03.2009, 08:57 PM
In the picture off the link whats the bronze colored washers for ? or are they bump stops ?
There are tiny bearings in the shock end and the brass things are bushings to act as spacers to fit in the rocker arms properly. My bearings eventually failed after a couple years, so I used a vice to press some 3mm spacers into the hole, and just ditch the bushings. They were the spacers included w/ the tie rods for the bearing carriers for bumpstop adjustments. I only ever used one setting (the tall hollow ball) and put the spacers to use.
