Originally Posted by BrianG
FYI, the update has been uploaded. Let me know if it is confusing or anything...
Did you consider listing the actual rollout value in the results with all the other calculated values? Then as you played around with different variables you could see how it affected your rollout. And you could still use the gearing table to find what would put you at 1:1
The two values are already there, so I suppose anyone who wanted to could divide it themselves (what I have been doing) but it would save that extra step.
