Originally Posted by cavy
Yeah that rx8 motor looks sweet  Did you have to grind down the chassis to run that 48 thooth? I ask because i just picked up the robinson gear and it hits the bottom.
I didn't need to but I'm using the Losi spur & I'm not sure if the RR is larger (I don't see how it could be?), which kit are you running?
