Originally Posted by Unsullied_Spy
Pics? Sounds to me like you pulled the rubber boot out of the can but it won't slide down the wires, is this right? The rear endbell is held on by screws, if you want to remove it just unscrew the endbell and tap the rotor on a hard surface and it should pop off.
No it tore the wire pretty bad, I took out the screws but it would not budge and I didnt want to force it till I knew it was safe.
