Click the little help question mark.
The 1:1 rollout rule simply is a method used by some to find the "ideal" gearing such that one revolution of the motor causes the tires to move one inch.
This rule does not suggest the gearing for maximum top speed, nor does it guarantee a cool running setup. It is simply a starting point. You should always still use ESC, motor, and battery temperatures as a guide.
