08.04.2009, 11:15 PM
You should be ok. 2.4GHz is quite resistant to noise (at least at the frequency the BEC runs at), and the DimensionEngineering BEC is just about noise-free. But you never know. Try it and see. If you have range problems, or other odd things, let us know because there are things you can do to reduce/eliminate the noise depending on where the interference is coming from...
