jsr
08.05.2009, 12:23 AM
They're off ebay. I don't remember the brand, but have taken decent punishment. They will definitely kill a cell out of the pack if I run a single 3s pack on my truggy, but I typically ran them in parallel for 170A+ constant current capability. They're rated for about 100A surge. Still a bit short of the 110A you mentioned. Seems like if I wanted to run them in series 6s config, I'd have to avoid fast throttle to WOT and not go from reverse to fwd.
When you say "increase punch control", do you mean lower the punch?
Sounds like even at 6s, the current demands are still pretty high. As mentioned, on 3s, the pack setup (3s2p) is rated for 170-180A so no problems, even in mid-air when I use the throttle to level out (which is when the single 3s packs popped). On 4s, I run 100A packs and I haven't had problems.
