sikeston34m
sikeston34m's Avatar
08.05.2009, 05:33 PM
Sorry to be off-topic, but how do those batteries fit for you? I just got the same ones and the case is exactly the right size, but I didn't account for the wires coming out of the side, which is what is giving me some issues. The wires don't allow the hatches to close, at least for me.
I was thinking of drilling a hole in side of the hatches, just big enough to fit the wires and deans plug through, so they can come out of the side.
What are your plans to get them to fit? If you already solved the issue can you explain what you did?
Thanks
This requires a little "out of the box" thinking.
Insert the pack into the compartment wires first, leaving enough room on the wire end for the wires to come around the end of the pack, then up through the existing wire holes.
This does shorten the lead length somewhat, but IMO, they are a bit long anyway.
Then insert your foam spacer, (or whatever spacer) to prevent back and forth shifting during the run.
By using this method, they work with the existing setup with no mods.
If you try to insert the pack, wires out, it's not very possible to make that sorta bend.
