sikeston34m
sikeston34m's Avatar
08.05.2009, 06:03 PM
Nice! Give this a try Dave, worked for me on my first try. Snug, but that's what you want. My one concern is that it seems like it might be stressful on the connections/wires having such a tight bend right next to the case pressed tightly against the battery compartment.
How long have you run your batteries like this sikeston? Any issues with kinking, pinching, or yanking a wire?
Inside the pack, all the wires are soldered to a common pcb board. In other words, they support each other. I don't think connection stress will be an issue.
Limp Silicone wire can handle bends like this. If you prevent the pack from shifting around inside the compartment, you will also hinder/prevent abrasive wear.
I've ran them 3 or 4 times like this and they still look like new. Good Performers too.
