08.06.2009, 01:12 AM
No Way! That's awesome... Honda Minimoto?
Have you managed to fill up the rear tire? How did you change the rear sprocket? Those are the two things I need to know, besides the throttle.
Yah, the minimoto. I used an angled nozzle attached to my air compressor to fill the tire. The way the big plastic pulley is held on is just fuckin' stupid. It is glued on to a small freewheeling sprocket on the rear wheel. I took it off just bu cutting it into quarters and prying each section off. I put a different sprocket on, simply by welding it next to the existing sprocket, then welding the freewheel mechanism closed, so the drive is locked, having the motor drag help slow the bike down. If you get on AIM we can talk about the bike and such.
