08.06.2009, 02:15 PM
Google translate worked great:
Tenshock 2220 / 8 vs. LMT 1930 / 6
Both engines cover virtually the same speed and power range and can be easily directly compare. Here the values MY TWO COPIES.
LMT: (255g, 2-Pole)
Ri: 5.1 mOhm
Io: 3.7 A (8V)
Load speed: approx 3450rpm / V at 50A
TS: (170g, 6-pole)
Ri: 5.1 mOhm
Io: 3.9 A (8V)
Load speed: approx 3400-3425rpm / V at 50A
For the load measurements, the LMT is 1% at full load and part load eta 2% more, this is the well-TS 1 / 3 lighter and has a lighter with less rotor inertia. The boat is probably the low efficiency to compensate for disadvantage.
And ... the TS costs only half of a 1930 HiAmp.
