JThiessen
JThiessen's Avatar
08.07.2009, 03:16 PM
Originally Posted by Finnster View Post
What is your FDR? If you don't load the motor up enough, sometimes it feels a bit sluggish. You may want to try going up some teeth, load the motor, pull more amps and power out of the motor. My trug is geared ~12-13:1, where as I tended to have the revo geared at 15-16:1.
IDK the diff ratio for the 8t's, but I did assume a worst case 4.11 ratio, and you are in a good range. Perhaps it is more psychological then...
Its 12.6:1. I've got that 48T supr that I can throw on it - other than that, I need to order some more of those long shanks.
