Originally Posted by suicideneil
Slottless stator, it will spin alot smoother than a slotted stator motor (neu, medusa).
Remove the screws from just the rear end, then tap the shaft against a hard surface, and the rear endbell will pop right off. By tap, I mean quite hard/firm- you may use a hammer to make life easier, just hold the motor firmly in your hand and hit the end of the shaft.
Ah, thank you! It went pretty easy, but first I was scared I would damage something so I didn't do that. The rotor is very small, I thought it was larger, but the motor looks good!
What's the difference between a slottless stator and a slotted stator? (Sorry, I'm a bit of a brushless noob...)
Thank you for your help!
