08.10.2009, 09:43 PM
They shouldnt need much shimming, at most one or two 10x8x0.5mm shims behind the head of the pinion gear, in between it & the inner bearing, just to set the pinion depth and mesh it correctly to the ring gear. Shouldnt have excessive play, or be tight feeling when rotaed by hand (got to allow a little play though).
