Gallagher
08.11.2009, 09:18 AM
Definitely 5mm the input shaft. I realized that after completing the rear diff. It is completely not compatible with the stock revo shaft or my aftermarket shaft (6mm inner diameter, 9mm bore for shaft pivot). Very sad about this. I may need adapter sleeves for my original shaft cups. By the way, my rear upper plate of G3R needs trim to fit in.
