kwik
08.11.2009, 02:25 PM
iv had a rethink and do you think a balsa chassis would work, with the 2mm balsa wood sandwiched by 1mm aluminum on each side (basicly because it would be easy to cut and its cheap and light.
but would it be rigid enough (may have front suspention nicked from another car... ) and could i cut the aluminum (T6) with a dremel? or should i use a hacksaw?
forgot to mention, i was planning a drag car type chassis...
thanks
chris
