lutach
lutach's Avatar
08.11.2009, 03:47 PM
Lutach -- I'm surprised you saw ANY difference between the MM and any other controller on the Mega motor. Tekin uses a similar run frequency to Castle, and Hobbywing uses a lower frequency (which would usually make a motor run hotter...) Hobbywing also doesn't track back-EMF very well compared to the MM, so if anything, I would expect the Hobbywing to run the motor slightly warmer than the MM. Could there have been some odd programming (very high timing for example?) on the MM?
I really don't know what caused the heat issues and I tried all the settings possible at that time. Right now I'm actually running (Testing) my micro 4 pole motor with a Tekin R1 and there's no heat issues at all.
I'll be getting in toch with you so we can work on some designs I have in mind.
