08.11.2009, 04:01 PM
SO, if I wanted to put a bore reducer on that shaft... is the bore reducer to slide on to the shaft, which then allows me to run 5mm shaft pinions. So, are the shafts on the CC 4600 type motors 1/8"? Or 4mm?
Never mind... I found it. 1/8". Thanks Jason! You're welcome Jason!
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
