simplechamp
simplechamp's Avatar
08.11.2009, 04:23 PM
The kits come with everything you need to run front and rear stock shafts or dogbones/CVDs.
But, the kit only comes with the proper stuff to run center dogbones/CVDs, not stock shafts. To run the stock center shafts you will need to buy the couplers I linked earlier from the RCM store.
I found this out the hard way, and had to place another order for the couplers. Also found out the hard way that the standard Revo center CVDs don't fit the E-Revo. The only E-revo CVD's I found are the Integy ones, and they aren't going to be compatible with the V3 kits without modifiying or getting custom parts. Kershaw Designs dogbones will work, but I want CVDs.
